tactical Member T Join Date Nov 2012 Location NE Posts 41 Feb 25, 2013 #1 Is there a way I can simulate a Modbus data table in RSLogix 500?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Feb 25, 2013 #2 Modscan32 will do that. http://www.google.com/#hl=en&sugexp...pw.r_qf.&fp=4837a5c9da8bdfb4&biw=1586&bih=807 http://www.plctalk.net/qanda/showthread.php?t=38750 Last edited: Feb 25, 2013
tactical Member OP T Join Date Nov 2012 Location NE Posts 41 Feb 25, 2013 #3 Mickey said: Modscan32 will do that. http://www.google.com/#hl=en&sugexp...pw.r_qf.&fp=4837a5c9da8bdfb4&biw=1586&bih=807 http://www.plctalk.net/qanda/showthread.php?t=38750 Click to expand... Thank you. Is there a way I can link this with the Emulator so when I run my program I can change the inputs?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 Feb 26, 2013 #4 I don't have an answer for you, I have never tried to communicate with the emulator. At least this will give the post a bump for others to see.
danw Lifetime Supporting Member Join Date Oct 2004 Location midwest, USA Posts 3,428 Feb 26, 2013 #5 If the intent is to simulate a table of values, wouldn't that table of values reside in a Modbus slave? If so, then Modscan 32 won't help because Modscan32 is a Modbus master application. Wintech's Modbus slave application is Modsim: http://www.win-tech.com/html/modbus1.htm I know that Simply Modbus has a slave application, although I haven't used it.
