Modbus TCP/IP to IC697CMM742 TCP/IP SRTP
fernandoguer
Feb 2018
Michigan
Hey Guys,
I am trying to figure out if I can send modbus tcp/ip commands to a IC697CMM742 that support tcp/ip (srtp). I guess I am a bit confused as to the terminology used in communication protocols. TCP/IP just encompasses a modbus command, so should the card be able to read said command if it doesnt specifically state it support modbus? (it says its srtp)
Please if anyone can help me with the reason for their answer that would really help me!
Thanks guys!!
No, TCP/IP is the transport layer, it means the device can send and receive raw bytes through TCP and nothing more.
A protocol like Modbus is needed above the transport layer for the devices to understand each other, but if your device does not specify that it has Modbus capability in the specs for sure it does not support it.
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
321
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
218
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
346
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
547
Hi There. I have PC to get few tags from PLC into C# windows forms application. What is the best and fastest way? I could not find Omron in...
314
