Modicon - CPU984-485E with Concept
Dan_B
Sep 2006
Montreal
I have presently a project using a processor 984-485E. Can I connect to it and program it using Concept?
Dan
The 984-485E processor can only be programmed with the 984 Ladder Logic editor of Concept.
But, I don't think you will be to connect as I am not sure Concept has the correct driver for a 485E.
It looks like the choice for 984-485E doesn't exist in Concept. I was thinking that maybe there is an update for this CPU that you can install extra.
As a matter of fact, I can connect with the PLC but I can only upload the program and all the word registers are replaced with "????".
Thank you
Dan
Concept can only do:
Momentum
Compact 258 and above CPU
Quantum
Atrium (the PC card PLC)
It can't do:
Micro
any of the 385/485/685/785 series
Compact below 258
and anything older, like the old 984A/B/X machines.
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
157
A lifetime ago I built a couple systems with Modicon Micro84 controllers that are still running. But today one of those died and they reached out...
93
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
101
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
318
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
109
