Ones_Zeros
I have two 1769-L32E Compact Logix PLC controllers.
One the remote plc I have two msg instructions
setup to read two separate ESD tags from the Main PLC.
This seems to work fine, I had some questions on
making sure I had this properly setup.
On the remote PLC after the msg instructions read
the two ESD tags from the main plc the .DN bit
stays on. I was just concerned that if the state was to
change on the main plc ESD tags that the remote plc
wouldn’t see this change.
For example anytime that the two ESD tags where
to change in state I want the remote plc to see this
change for both tags.
Do I need to do anything differently on the two msg instructions?
Is it normal for the .dn bit to stay on or do I need to have this
on a timer so it would reset the .en & .dn bits
of the msg instructions?
I appreciate the help and guidance
