multiple alarm viewers crimson 3
leblar13
Jul 2010
louisiana
I know there has to be a way to do this.
I have two tags.... I want to set up alarms and have one show up in Alarm viewer 1 and the other in Alarm viewer 2.
I know I must be missing something.
Hello,
Sorry but all alarm viewers will show the same data. There is not a way to show only certain alarms on certain viewers.
Jeremy
Hello Jeremy. The ability to classify and/or filter alarms based on severity might be something worth consideration in a future release. Having all alarms in a single class can be too limiting for many applications.
Thanks for all you do.
Paul
I've used the following with good results. Set the trigger of the tags to auto accept. The Alarm Viwer displays only active faults. The Event viewer is set to show date & time while the clear button has security [hasaccess(2)]to operate. The Event viewer keeps a historical record of the faults that the operators can't clear. Very useful for problem solving.
Using TIA Portal v17, SIMATIC S7-1500 PLC. I am trying to write an alarm that will trigger for multiple sources, and output the triggering...
2,533
Well, reading the thread below on phone dialer inspired me to ask the hive here for some ideas...
4,858
I have a huge list of alarms that triggers an alarm bell. I am currently doing it this way (I have more than 4 alarms normally): My question is...
4,012
I have an application here than uses analog alarms in RSView32. It uses multiple thresholds to trigger different alarms (e.g. LL, L, H and HH)...
5,758
Hello, I am new here and hope this doesn't come accross as a rookie question, but this is only my second application using RSView. The first was...
2,480
