New Rockwell error after Windows Update
Any Mouse
Aug 2015
Rockville, MD
Good morning all,
After a weekly automated update from IT, we are now getting the following fatal error during startup on all computers: 0xc015000f
I tried uninstalling all Rockwell software and then reinstalling everything from the cd, but it still crashes. I've had trouble finding information about this error through Google, and undoing the IT update isn't an option. I don't have techconnect service. Any ideas?
Thanks guys.
I don't know if they _still_ do, but, at one time, Rockwell tabulated a list of "approved and tested" Microsoft Updates, mostly due to a long-ago problem in Austrailia concerning time zones and daylight savings time, as I recall the story.
Either way, if it remains, you should be able to find in via the Knowledgebase
I got a very similar error on 2 computers after installing the new 2.74 FT download. Rockwell told me to uninstall all FT programs & reinstall, during uninstall it asks if you're uninstalling to revert to a previous version.
Uninstall: FactoryTalk Activation Manager
Uninstall: FactoryTalk [either configuration utility or server] if exists
Change: FactoryTalk Diagnostics, then click Remove when prompted
Reboot & reinstall RS5000, but unselect RS5000 from what you want to install
Welcome to the forum.
#1 Keep IT away from the programming pc's unless absolutely necessary.
Although I am working in the IT group, we are the plc programmers and are very aware of when to update pc's.
Carry the pc's back to the IT group and tell them to fix the problem.
Tell your manager what happened and that all programming pc's are down.
When machinery goes down and you cannot fix the problem, Upper management WILL hear of the issue.
That's what eventually had to be done at my last job before the company moved.
regards,
james
I read some things somewhere that said it's one of two problems:
1) User Account Control needs to be turned off. (you can test if this is your issue by finding the RS5000.exe for your revision and run it as administrator)
2) The Startup page needs to be disabled in the registry
HKEY_CURRENT_USER\Software\Rockwell Software\RSLogix 5000\Start page
Set NeverShow to 1 (this should be default IMO)
Then I heard that if none of those work, uninstall all .net 4 framework, then find Microsoft's standalone .net 4 framework installer.
regards,
james
yep.
fastest way to an unusable laptop is to let IT manage it. I like to call it the IT virus.
On my base w7 machine, everything works perfect. I have a w10 clone that I wanted to test rockwell on, even though it isn't supported. I have...
1,991
Hi everyone... I'm not a AB expert.. I'm using L74 controller, Rm2 redenduncy module, EN2TR and EN2T module (on each chassis) on my control logix...
2,087
While trying to get a new Activation for Rockwell engineering softwares, the following error keeps popping up. What could be the issue? A system...
2,759
Is anyone else experiencing an issue when trying to download from Rockwell's site?
1,433
I am learning how to use the View Designer software. I have worked with FactoryTalk View ME and SE but this is quite a bit different. I have...
2,690
