Novice: programming error
PLFit
Mar 2013
Antwerp
This problem is a little easy for this board but it is driving me mad so i can use the help.
I'm using a PID FB from the TwinCAT PLC Library: Controller Toolbox and i'm trying to set values for the stParams parameters, but i keep getting a syntax error (4024).
Here's (see the attachment) a screenshot of the problem.
Because the same error message "Error 4024: Expecting "." before "." appears on all Rungs where you have entered a text comment (28-29, 31-34, 36-37), and considering that on Rungs 31, 36, and 37 that you entered only numbers (followed by a text comment), then I think that you may have used incorrect syntax to enter your comments. Check your software Programming manual carefully for the correct syntax.
Disclaimer Notice: I am not a Twincat programmer, nor do I know anything about that brand. My only claim is that I can read pretty good.
I think you are declaring the parametres to stParams wrong way. Most likely the errors refer to the "."-sign in for example stParams.fKp.
I don't have codesys at hand to verify this, but I think you need to see how the variables are declared to arrays, since stParams is declared as a structure ST_CTRL_PID_PARAMS.
Hi, first time poster just wondering if anyone has any tips for a novice of the PLC world, I've worked with them a fair bit within schooling and...
3,266
We're a used machinery merchant and have a Siemens PLC that has lost its program due to a dead battery. We have the software to download but, at...
22
6,655
Hi I’ve got a door and window switch from RS (190-1011) with a 4 core cabl - red, white, green, and yellow . The red and white are the switch and...
1,363
I'm self taught so far, so hang with me as I try to explain my issue. I've got an archived program file for a PVP6 that I'm opening on FT ME ver...
2,604
If 95% of our PLCs are AB (micro 1500, slc5/03,04 make up the bulk) what would be the language to learn to use scripting? Also to move towards...
2,172
