NT Series System Installer v2.00
saksas
Oct 2008
Miami
Hi everybody,
I got a problem with an NT31C-ST141-EV1 that show this message ¨System Program not exist or incorrect¨. It says that has the System Installer Ver. 2.00. I have made everything with the two versions that I have (1.11 and 1.33)and I got nothing so I supose it must be done with ver 2.00 but I don´t know where to find it? Do you?
Thanks.
The System Installer is included with the NTST software.
Omron Part Number NT-ZJCAT1-EV4. Your local Omron distributor should be able to help you with this.
You also MUST use a full handshake cable to load the system program. Reference Omron Manual V062.
Hope this will help.
Getting worse
Hi Guys,
I am getting worse. I downloaded the system Installer v2.00 and the history is the same and now I have a new problem, the software gives me a communication error. I’ve been looking for that and found it could be a hardware error that implies that the useful life of flash memory is weak. What do you think?
Hi all, I have old 1734-OE2C series A and B parts knocking around gathering dust. A customer would like one installed on their machine because...
2,019
Hi everybody I am using a servo which model is MR-J3-10B (GA). Now I have an alarm code 96(home position setting warning). How can i fix it?Please...
1,574
What does mean by the following instructions? DP.SFCS H3E1 K1 DP.SFCS H3E1 K2 DP.SFCS H3E1 K3 DP.SFCS H3E1 K4 DP.SFCS H3E1 K10 DP.SFCS H3E1 K20...
1,846
Hey guys, I've searched a lot to find the S7 PLC operating system but I couldn't find anything. Can anybody help me on this? and any helpful...
15,999
Hi, I have a Q series PLC (Q06UDEH) and I'm using GX IEC Developer. On compiling I'm getting the error message: F1034 More bit addresses needed...
3,749
