NT30C touch screen doesn't work
kim5585784
Jun 2004
HI:
I have an old Touch screen NT30C ,but it doesn't work,I have tried many times and it always display "connecting to host " messages
I used NTST software and set connecting items in the software.
I soildered a cable for connecting between PC and touch screen .
I am not sure the soldering is right or not?according to circuit.
I hope anyone can help me !
Thank you!
Kim, Jay is spot on with that, you need to touch the bottom left and top right of the screen in the corners. This will bring up the screen that allows you to put the touchscreen into Transmit Mode.
You might find that the PC will still not upload to the screen. In this case it may be necessary to Initialise the memory. In order to do this, make sure that Dip Switch 2 at the back of the screen is Off. Then, press the two corners to bring up the menu and select Configure (Can't remember what its called but whichever word means configure :rolleyes: Not Transmit and Not Quit!)
Then go to the Screen Memory option and select Yes to initialise.
Then you can upload and set the dip switch 2 back to On ie. Memory protected.
Hi Folks, I have an OMRON touch screen that I would like to test. I have a 3 CD's CX-One 30-Day Free Trial, Ver 1.10. Hopefully it is not...
1,577
i have a machine that has been in service for 12 years. it consists of a CQM1 and an NT30C. the NT30C has a message "connecting to host". i have...
1,878
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
173
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
