Omran plc cpm1a
JIGs_2203
Mar 2012
dubai
HI,i want to use timer in cpm1a plc, i have SYSwin software, i make download backup from plc, now i want add one timer 5minute after that generate one output bit.i use TIM000 and value #0005 but timer always enable. without give comand for enable. so what i will do ?
even i put #0020 sec time timer not working...i try TIM000,TMI 015,TIM016, but all timer going direct ON mode without any enable command, in my backup program using timer TIM011 to TIM014 its perfect work. i m very confuse for this.
You need to put a contact in front of the timer to enable it and reset it.
Omran plc CPM1A
sorry for late reply, i make attachment file in this u can see what i make program. please guide me for this.
If HR00.01=False, Timer output if always False.
If HR00.01=True, Timer output becomes True 030.0 seconds after (HR00.01 must remain True all this time).
So, by controlling HR00.01, you control Timer output.
Remember that HR00.01 keeps its state even on power-off.
Try to use bigger TIM number, I think TIM000 is milisecond timer(timebase = 1ms). Use timer TIM030 exapmle for time-base 0,1sec
Omran plc CPM1A
but problem is without this HR00.01 True ,Timer always True. thats the reason my output always True..its nothing effect of HR00.01 True or False.
TIM000 can be what you want - TIMH is the high speed timer and these have to be in the lower timer numbers. TIM000 is fine as long you do not want to use high speed timers.
the relevant point is the HR00.01 is retentive and if you do not turn it off somewhere in the program it will remain on and the timere will remain timed out until it is reset to off in the code, unless power is lost to the PLC of course and then the timer will time out once more.
You have to turn the input to the timer on and off or it will not work!
Read the mnual - also read the manual for TIMH but it will not help you - you hav to turn the input on and off!
I think the first 16 timers T0-T15 are high speed timers, the timers value is in 100th seconds so a value #0300 would be only 3secs.
Hi Everyone, i have cv501 keyence and c200Hg omran plc for getting data from cv501 to c200hg memory. I have written the program but the plc...
12,774
Hi evry body, Please experts I need your help. I'm working on project which focus on how to convert omran mnemonics to Simatic step 7 ?. - is...
1,538
Hi I am having OMRAN CQM1 (CPU21) PLC, my junior was handling it, suddenly it is showing IO bus error its code is 0x00C0. I could not find out...
20,074
We are using Omran Sysmac C500 PLC but we do not have the software and connecting cable. Can anybody let me know what software & connecting cable...
3,044
Hi everyone, I need a favor from you that how to write the serial communication program using RXD and TXD command in the CX programmer. can you...
3,405
