OMRON CPM2A and Intermec 3240 Serial Printer
genogin
May 2008
Tenn
I'm having trouble communicating from PLC to printer. I can use Hyperterminal to go from my PC to the printer and send the file to the printer and it will print. I can send the same file from the PLC to my PC using Hyperterminal and I can see that it sent the correct file. The cable works because I can do a data dump from the printer after I send the file from the PLC, and see that it is the file I was trying to send. I have the comm port on the PLC set up just like another machine with the same model printer and a different model (CJ1M) but OMRON tech says the ports should work the same when set up in the same manner. I am wondering if there may be some kind of framing issue with the file when I send it. If anyone has any information that could be helpful, I would greatly appreciate it.
Serial comm instruction are a bit different between the C series (CPM2) and CJ series.
Do you have an end of string character set in the PLC settings for the CPM2?
Your printer may require a form feed character at the end of the string to print the page.
On the CJ1M, are you using the on board serial port or a serial communication module?
Just a couple of quick thoughts.
Hi all, My name is Firdaus. I am a teacher. And for the next semester I have to teach PLC to student. The problem is, I just move to this school...
2,008
Hi Folks. I have a problem with an Omron CPM2A-60CDT1-D High Speed Counter. It had been working well, the problem arose when a very minor program...
1,473
Hi Folks. I have a problem with an Omron CPM2A High Speed Counter. It had been working well, but the problem is that a program change was...
1,384
Omron's CPM2A has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be...
1,525
Our company using OMRON sysmac CPM2A plc for small machine. presently we dont have the software to connect to PLC. Please anyone can send me the...
1,557
