Omron & Kistler maxymos
Tommycai
Aug 2011
KY
120
anyone ever connect an Omron CJ2MCPU33 to a Kistler maxymos. I have the EDS file and made the IO using the H Bits but still giving me red on the runnning side and I see no outputs or inputs on the plc anyone ever do this before or is there an area where I can find the code of why it is not working? I have a code of 1:0204 when monitoring the CPU in integrator? What manual do I need to see what this means?
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
55
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
187
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
75
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
121
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
283
