P&ID representation
Charbel
Jan 2012
Beirut
307
Dear,
I trying to proper represent a P&ID logic by showing a selector switch that switches between relay and PLC mode as indicated.
please advise if it is correct or it needs to be adjusted.
Any comment is really appreciated,
Charbel
- I would prefer to point HS-xxxx to the selector symbol and delete both rigth/left lines.
- I'm not sure about HSI-xxxx. I found people used HI or HL in other diagrams.
- That tree of selectors under the relays control is a little confusing. I'd not know how to identify them on the field using your diagram.
This is totally proper if designed this way. If you are allowing for two control modes, one purely as hardwired level transmitters or switches wired directly to the pump controls versus the PLC handling the level control. The HS would allow an operator to switch between the two modes.
However, it's a little hard to see some of the symbols on your expanded view to determine what you're trying to do.
Maybe give us more explanation of you system.
I am using Modbus to read 36 registers from a ML1200. 2 of those registers are suppose to be L11 data and 2 of the registers are F8 data. Long...
1,393
Firs of all I'm working with Structured Text on B&R Automation Studio 4.0: I have a binary message on a string (collected from serial port). The...
8,200
Hi, I have a small question regarding representation of 16 bit data by PLC. I have a parameter that uses 16 bit data. I have thought of using...
1,926
I have a ML1400 Series B controller which is integrated with Wonderware via Modbus TCP. I have a flow totalizer in the ML as a floating point...
6,870
This is true of every forum that I have visited. This is an accurate graphical representation of about 80% of all Forum questions ever asked...
5,105
