Pep vm30
opto81
Mar 2009
Ontario
Hello,
We are trying to extend the life of our existing VME system, which has PEP modular computers VM30 CPU Part# 544-001 (VM 30 – CPU for VME bus, 68EC030 25 MHZ CPU, 256K SRAM), which is no longer available as per Kontron AG (owner of PEP). Can you please source any used / inventory VM 30 modules.
Jeremy
Ouch ! I have seen the PEP once before, and then that user dropped it for a regular PLC. I think it was more because of declining user base than because of any dissatisfaction with it.
I think you chances of finding some spare PEP CPUs are very slim indeed.
As far as I remember, it could be programmed in the IEC languages and also in C.
If you have access to the source code, you can see what language it has been programmed in, and start planning for the inevitable exchange.
The only PLC I know of that supports both IEC and C languages is B&R.
If only IEC has been used, you have many more options.
I DON'T KNOW WHERE I CAN FIND SOME INFORMATION ABOUT VM30 PEP MODULAR COMPUTER. IF SOMEBODY CAN GIVE ME SOME DOCUMENTATION CAN CONTACT ME TO...
6,179
Hi all Now i'm using redlion as device to map I/O from PEP plc (Smart Base) In the communications, i used RS-232 Comms Port - ICP DAS - DCON...
2,204
dear all, i just wanted clarification and info's abt PEP's technical {advantages} and {disadvantages}, wt makes it different than others like...
1,899
Hello All. Im am in need of graphic cards for pep(VM30) The card is called VGPM, and the critical components is the graphical processors and the...
2,555
Dear All Is there anyone that used PEP, Smart IO, and used The ISAGraph software for programming PLC...... if there anyone, it would be great so...
3,116
