Pl707-7 Comms.
demagdave
May 2003
We have an old copy of PL707-7 on floppies which we used with Telemec Nano plc's. We have now got a new laptop running windows XP and we can't open comms with the plc. Schneider said they don't support this platform any more and are concentrating on the new Twido plc. Can any one help please?
DOS
PL707 software is DOS based. While it has been known to work on WIN98SE, I have never been able to get it to work on WIN2000/ME/XP. It seems that Microsoft doesn't believe in serial communications any more.
If you want to continue using this software, your only solution is to find an older computer.
The new TWIDO software can import .ASC files exported by PL707, of course you would need to change to new hardware also.
Thanks Jim, one of my colleagues suggested installing Virtual PC on the laptop and running Win95 in a window to run the application. Any views?
Dave.
Hi I need to upgrade a number of modicon nano plc's but cant find where to get software. i know i need PL707. i do have have the Idec software and...
4,629
Does anyone know where I would get a copy of Telemecanique PL707? Thanks
2,032
Greetings! Does anyone know how to use a bit sequencer in Tele PL707? I'm used to the way GEFANUC does it... Cheers, Byron
4,259
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
105
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
391
