plc panasonic fp-x0l30r
nor
Jun 2016
Perak
hi,
i need to ask about fp win pro 7.. i am currently doing the development project pick and place using panasonic plc but i encounter problem when trying to execute the program.. when i run the combining ladder diagram of movement and pneumatics it will miss a step from the program and continue with other step.. i am beginner in plc and i dont know how to fix this problem.. can anyone help me?
You will have to find out why your program is missing a step. One method is to place an end statement at the end of each step and ensure that it will get executed. Keep adding the steps until you discover where the error is happening.
Once you have found the error, you can post the ladder logic and what is happening. We can then assist you in fixing the logic.
Hope this helps,
tq gclshortt.. i have done that but it still missing step when combining all the rung. can i ask what is the possibilities for that problem happen?
please help me
this is the ladder diagram for my pick and place..as you can see open and close grip is not trigger but the timer still counting to the next step.. i really dont know how to fix it anymore..
I guess its because you use the open_grip coil and close_grip coil more than once in the program. The last coil status will always prevail.
Try experimenting with Set/Reset coil.
thank for the reply...so, that's mean plc ladder diagram cannot use repetitive coil? do you need to determine whether it is in set or reset condition?
Check this thread: http://www.plctalk.net/qanda/showthread.php?t=4365
Usually you won't use repetitive coils because of the undesirable behavior it produces. Unless you understands how the PLC scanning works.
Another way to cure this coils is to substitute the repetitive coils with a different memory tag, Then connect them in OR at the end.
Change the coil after time2 to "time2_open_grip", time8 open_grip to "time8_open_grip", time3 close_grip to "time3_close_grip", and time12 close_grip to "time12_close_grip".
Then create a new rung at the end of the ladder, and connect them in parallel like the one below.
time2_open_grip
---||--------------|------(open_grip)
time8_open_grip|
time3_close_grip
---||---------------|------(close_grip)
time12_close_grip|
I am involved with the Panasonic FP7 for my final year project. I am doing a water distribution system and I want to use interrupt program for the...
730
Hello friends. I have a problem after a backup attempt. I lost all programming in plc panasonic afpx c30t, is it possible to perform a restoration...
926
Currently we are using panasonic FP-e and want to connect the encoder and use the high-speed counter to let the motor receive the signal Is there...
1,079
Hello Guys, I spent some time searching the web to learn how to generate the report (to be printed out or to be saved as pdf file) which would...
1,212
So I started working on this old italian machine and it has an FP0 plc, I am using the fpwin gr 2.7 software and it lets me connect to it and...
3,165
