Ventax Member V Join Date Mar 2009 Location Kitchener Posts 34 Oct 25, 2011 #1 What is the most inexpensive PLC that supports trig functions (sin, cos, tan). Thanks in advance
bernie_carlton Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Yakima, Washington Posts 6,413 Oct 25, 2011 #2 The AutomationDirect Click has those functions. It's fairly inexpensive.
ndzied1 Lifetime Supporting Member Join Date Aug 2002 Location Chicago, Illinois Posts 2,857 Oct 25, 2011 #3 Maybe the ELC from Eaton? <disclaimer, I work for an Eaton Electrical distributor>
RussB Lifetime Supporting Member Join Date Oct 2003 Location Michigan Posts 2,914 Oct 25, 2011 #4 Ventax said: What is the most inexpensive PLC that supports trig functions (sin, cos, tan). Thanks in advance Click to expand... Maybe the GEIP VersaMax Nano? (<$200 USD)
BobB Lifetime Supporting Member Join Date Jun 2002 Location Sydney Posts 4,557 Oct 25, 2011 #5 Omron CP1 series - also has double floating point sine, cos and tan, ASIN, ACOS, ATAN, and full 32 qnd 64 bit floating point maths.
DamianInRochester Lifetime Supporting Member Join Date Jan 2011 Location Rochester NY Posts 1,292 Oct 25, 2011 #6 Unitronics is also an option it you also require some sort of HMI and depending on how many IO are required. Software is free as well.
