PLC2 -> PLC5 conversion - .LIB file
tdanza
Apr 2008
Los Angeles
I'm attempting to convert a PLC2 program to PLC5, having trouble getting it into RSLogix 5. The 6300-um001-en-p.pdf guide does not detail this last step, and references "PLC-5 Programming Software User's Manual 6200-6.5.5" which I have not been able to find.
How do I get the .LIB file to convert into a PLC-5 project?
I know this conversion has been done before with the software I have access to (I have limited access to PLC2TOPLC5 and PLC2 DOS programs).
Thanks!
allen bradley had a conversion package that will convert the software.
you might find a distributor that still has the software and will do it for you.
you might also try an oem who will do it for a price.
regards,
james
As I understand it, the *.LIB file has to be converted to a *.PC5 file before it can be imported into PLC-5 software.
That's done by a utility called LIB2PC5.EXE which ought to be in the TOPLC5 software directory.
It's just a command-line utility; execute it from the TOPLC5 directory like this: LIB2PC5 C:\PLC2\PROGS\file.lib
Open the resulting *.PC5 file with RSLogix 5.
I am working on a PLC2 to PLC5 conversion. It appears that most everything converted ok but I am getting lost with all the math conversions. In...
7,764
Hi, We are converting a PLC2 system into PLC5. Can the 1771-DR & 1771-AL be reused? If not what is the engineering involved? Please guide...
5,473
Howdy All, Just curious if anyone has used the AB PLC2 to PLC5 conversion program that comes with RSLogix 5 or APS software. I was wondering how...
7,615
It's a PLC2/30 system, besides the regular I/O, it has a 1771-VHSC, 1771-KA2, and 1771-KE. You can PM me. TIA.
1,532
I'm trying to use some old hardware - a 1771-IF analog card and a 1771-IK encoder card - with a PLC 5/60. Do these cards only work in 2 slot...
7,516
