This is a bit off topic with respect to PLCs, but since there are many experienced engineers on here, I'll give it a try.
We are commissioning a diesel electric platform supply vessel, and we are doing load testing on the main switchboard.
When we run one generator set solo, the load from the loadbank is very stable.
The output is very stable.
When we run two in parallel, the load is not stable on the generators, even if the loadbank has stable load.
We have been doing some measurements, and it seems that there are power fluctuations between the generators in parallel. It is not due to any engine governor issues, because the fluctuations are too fast, more than 5 hz.
We have used several measuring devices, so we know that the fluctuations are real. They are eapprox 5-6 % of the rated kw of the generator sets.
The engines are 1800 rpm, and they are approx. 1500 kw each.
It seems that there is some kind of natural phenomenon where power is fluctuating between the generators. They are considering if flexible coupling between engine and generator might have wrong specification.
Any ideas anybody ?
Any ideas anybody ?
