Powerflex HMI Add-On Help
Mar 2012
Hovering Over Keyboards
Hello all,
New to the forums and New user of Powerflex drives. I am currently working on a project which will include RSLogix 5K, 3 Powerflex 753's, and FactoryTalk SE. I downloaded the Add-on profile for the Powerflex to use in the Logix 5K. I have that set up in my program, then downloaded the faceplates for the Powerflex 753's to use on my HMI. The tags were different on the Faceplates than what I have in my Logix program. So I imported the Add-on instruction for the powerflex into the Add-on folder in Logix. Now I see the tags that match the HMI faceplate but how are they mapped over? *Note - I am building this program offline from the drives. Its my first time working with powerflex so I am learning as I go. Any help would be appreciated. Thanks(y)
Hi fellas, Hoping someone can help me get started with this. I'm a little out of my comfort zone trying to set up communication with a ProFace...
844
Hello all! I have a simple motor control cabinet and I would like to update the existing vfd with 525 and add an HMI (probably C-more EA9) I...
3,640
I have to use two mapleview hmi to control one powerflex 4 drive. Best I can discern from what I read, you can only enter a frequency to the drive...
1,682
This is a troubleshooting problem. I have two AB Powerflex 700 VFD drives that report status on the HIM but do not always report thru RSLinx to...
3,869
Hello, (Simplified explanation)I have a Powerflex 400 running a fan/vacum system that sometimes gets overloaded and clogged. What is happening...
4,806
