I use a portable PC (step5 v 7.0) to connect CPU928B, the problem is communication not stable(It will stable if use PC to connect PLC): I can online monitor s5 program, but PLC timeout frequently. I think the portable PC¡¯s com1 port not good, so I had to change com1¡¯s settings. Can someone tell me how can I config parameter in s5@@@@AS.ini? How to change the timeout between data?
[COM1:]
IO=3f8
IRQ=4
BAUD=9600
STOPBITS=2
PARITY=EVEN
RESPONSE_TIME=2000
CHAR_TIME=15000
BLOCK_LENGTH=256
BLOCK_TIME=200
TIME_AFTER_BREAK=0
SIO_SPEED=SLOW
[COM1:]
IO=3f8
IRQ=4
BAUD=9600
STOPBITS=2
PARITY=EVEN
RESPONSE_TIME=2000
CHAR_TIME=15000
BLOCK_LENGTH=256
BLOCK_TIME=200
TIME_AFTER_BREAK=0
SIO_SPEED=SLOW
