rubik2511
hi!
I was reading this book and part of declaration of variables in data blocks
found the following information:
This column shows you how the variables in the variable declaration of the function
block are declared:
• Input parameter (IN)
• Output parameter (OUT)
• In/out parameter (IN_OUT)
• Static data (STAT)
The declared temporary local data of the function block are not in the instance data
block.
my question is: what is the difference between input, output and input / output parameter? which is
referred to my entries and exits of the plc?
thanks for the help I'm researching and learning.
Greetings
block are declared:
block.
Greetings
