monkeyhead
I've seen VFDs protected with all of the following... Is there any standard dictating what type of device a a VFD should be protected with in the US?
On the little systems I've done and where I've added VFD controlled motors to existing systems, I've always stuck to fuse blocks, but on our OEM and Integrator supplied control systems, it seems to be a free for all in what gets used to provide circuit protection to the inverters.
I haven't looked super hard, but I poked around quickly and couldn't find any specific guidelines in the NEC or NFPA 79.
- UL 508 Type E Circuit Breaker (motor overload)
- UL 1077 Supplementary Circuit Breaker (possibly dual rated w/ UL 508)
- UL 512 Fuse Blocks with type CC fuses
