ProTool, changing of memory bit
Valera
Jan 2004
Saransk town Russia
147
I know you can say to me RFTM, but please sorry to me.
My question: I want to change value of memory bit (when button FX is pushed memory bit M171.1 is true, when I cancel push button Fx memory bit M171.1 is false
(in Step7 M171.1 (symbol name is "Button_OP_panel") is used
A "Button_OP_panel"
L S5T#2S
SD "Timer_button"
A "Timer_button"
= "M_Button_Reset"
A "M_Button_Reset"
AN "M_reset"
JC CYCL
Thanks in advance for answer (sorry for bad english)
In Protool: Open System .. Screen/keys.
Click the button you want to assign the "reset" function.
Select one of the functions:
- Set bit.
- Set bit in tag.
- Set bit while keypressed.
I would use "set bit" and evaluate the tag in the PLC with a oneshot.
When the oneshot is activated I would do the resetting AND set the bit back to zero.
In that way your system cannot hang if there is a comms failure, and even a short keypress will be detected properly.
I did this
Function key F1->Functions->Function selected/Tag set value=1 (MB172)next branch of tree Tag set value=0(MB172)
And what I get: when I touch F1 MB172 change to 1 and (I think after OP is cycle 1s) then change to 0.
But I want that MB172 change to 1 when I push F1 and change to 0 when I cancel pushing. (And I can't change M172.0 to true and false because I did't found this option, only for byte I found one)
Thats the reason why you should only use one "set bit" function.
Then evaluate the bit in the S7 program, and reset the bit in the S7 program.
Its the most robust way to do it.
Its a bad idea to try to make a timed impulse from the Operator panel.
Well, and what about permanent dealing of patterns, sample of image, algorithm of WinCC v6.0 Step7 Protool etc. Now I put some samples to file...
3,864
Does anyone know where I can download the Simatic ProTool software? Thanks.
1,533
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,410
Asking for a friend who has a Protool v1.0 project. He needs to migrate it, and for that he needs to first migrate to v2.51 which he does not...
1,170
So I am working on a machine where the PC has died. The PC was running Windows XP, Protool RT, Step7 V5.3, SimoComU and other software. The...
2,479
