Pylogix Local UDT
Taylor Turner
Sep 2020
Midwest
78
Can I not access locally defined UDT data?
Scope..
Task>Prog1>Parameters and Local Tags(Test1 = real)(UTD.Test2 = real)
Code:
#To access the local tag.. (Works)
$PLC.Read('Program:Prog1.Test1').Value
#To access the UDT tag.. (Does not work)
$PLC.Read('Program:Prog1.UDT.Test2').Value
That appears to be a response from "GetProgramTagList()", not a read.
Edit: So somewhere you are calling GetProgramTagList("Program Name") and it is not finding that program name.
Thanks a ton...
Stat info: My program runs ~180ms faster by reading the tags as a dictionary. (09_multi_read_faster.py)
Thanks a ton...
Yes, lists are much faster because multiple reads are packed into a single packet, where if you call Read one at a time, they each get their own packet. I have a couple of new things to hopefully further increase performance, it's just a matter of finding the time.
Another note:
I have an application using Pylogix as middleware amung three devices. This application uses the asyncio, transports and Protocol module to talk to one of the devices(not the PLC). The data_received runs when there is a change for me. I'm working a second project where I need to observe tag changes from the PLC. I don't want to poll pylogix constantly, are there any alternatives you can think of? Currently looking into a MSG instruction and PyDispatcher.
Another note:
Pylogix doesn't have a "listen" function, thought that is an interesting idea, a few people have asked for over the years.
What is your concern with constantly polling the tag? How frequently would you be polling it?
Ideally a script would run only when the plc tells it to. I have yet to test the performance by polling, your 06_read_loop.py. My only concern right now is in theory. Polling hogs a thread and voids RTOS principals, eventually I need to account for a battery powered system. I'll code it up and get an application point of view though.
Hey everyone, I am looking for a tool to parse PLC data and I believe pylogix may be the best approach. I am very new with python but can see its...
870
If anyone is interested, I have an experimental branch on github that adds an “adapter” module to pylogix, which will allow you to interface to a...
1,144
I am not the best in python... "What is a library?" Said structured text. I am trying to make a simple plot by grabbing tag values from pylogix...
30
6,482
I am trying to use pylogix to write to a string array ID_Data_Table_Name. In the array there are 200 possible entries. For...
4,039
I'm currently working with pylogix and have no trouble reading and writing tags. My problem is, I would like to be able to read (and write) I/O...
3,716
