RedLion Crimson 3.0 Help
DavidD93
Oct 2017
UK
I'm currently very new to both Crimson 3.0 and a very old Siemens TI505 PLC but I'm struggling trying to achieve my goal.
What I would like to do is at 06:00 and 18:00 for the HMI clock to activate a bit in my programme which will essentially reset a counter. (Shift clock). I've been told not to bother with the PLC inboard clock as it's rubbish and other machines have used the inboard clock but every time there is power downs or CPU changes it just loses it's time.
I am struggling to find any support online with Crimson 3.0 so any help would be great.
Thanks,
David
Set up a numeric tag with the Data Source as GetHour(GetNow())
This will return the clock hour. On the Triggers tab, set up Trigger One for Data Match and put the value at 6. In the action field, put PLC_Bit := 1 (where PLC_Bit is the tag in the PLC you want to turn on at 6 am.)
Set up Trigger Two the same way but use 18 as the data match value. In the PLC, perform your action when the bit is true and then reset it.
You could also put a tag in the data match fields to make the time of your actions adjustable at run time.
Redlion G306 I'm trying to set the minimum value data limit of a tag named CT01_HighAlarmSet where the minimum value is...
2,267
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
864
Following on from another thread, I just downloaded Crimson 3.2 and it now supports CR and Graphite HMIs. Time for a 'play' :-) It seems to have...
2,030
