Rehosting license _Rs linx 4.10
rejoe.koshy
Dec 2011
kolkata
195
Hey guys,
I have Rs Linx 4.10 (single node) installed on a PC, which is activated using codemeter.
In line with a customer requirement, I want to rehost the license and bind it to the hard disk of another PC.The rehosting process has been completed succesfully but I am not able to bind the license to hard disk serial number since no option for the same is available.
Any assistance would be highly appreciated since I have limited understanding of codemeter licensing technology.
Pls help.
I'm guessing the OP has one of the paid versions of RSLinx. When going through a FactoryTalk activation I recall that there used to be a popup menu or something that would let you select the binding method, i.e. disk serial number or MAC address. At some point I think they removed the choices but I believe you can still enter it manually. In the binding field just type in DISK_SERIAL_NUM=xxxxxxxx (replacing the x's of course).
If you don't know the serial number then on the PC you are rehosting to, type vol at a command prompt (CMD) to get the volume serial number for the local hard disk drive. Then enter as Kolyur has advised.
Regards,
George
Regards,
George
I wish I had that option to enter the serial number but i couldnt find any.( i guess its not there!). I think some versions of the software can only be activated by codemeter...any idea if thats the case or not....searched knowledge base but to no avail..��
Hi rejoe.koshy,
rejoe.koshy said:
...The rehosting process has been completed succesfully...
If so, this process should have returned the license to the Rockwell licensing server and should now be available for use on another computer.
On the computer you are moving the license to, have you access to the Internet or not?
This will matter in how you should proceed to get the license onto this other computer.
Maybe explain what you are doing/seeing in FactoryTalk Activation Manager on the new computer when you are trying to get the license activated?
Regards,
George
Anyone have problems/solutions with Rehosting Studio 5000 to a new computer. Our IT department successfully Rehosted 2 laptops, but the other 2...
156
Hi, During Activation Rehosting(with Internet) of Studio 5000 there was an connectivity error which caused my License to be removed from laptop...
618
I recently got an upgraded computer from IT. I have installed RS5000 on the new computer and I need to rehost the activation from my old computer...
2,574
I just want to transfer the licenses of my rslogix 500 and rslogix 5000 and rslinx classic to another pc. but when i looked at the factorytalk...
23
19,628
I am rehosting, well trying to, and i quickly learned i do not know what information i am going to need. license numbers, and all that, when i...
1,415
