Rockwell EN2T sending SNMP message?
mugged99
Feb 2015
MI
22
I'm trying to figure out if it's possible for an EN2T card along with an L7x processor be used to send SNMP protocol messages? I'm pretty sure the card can receive SNMP queries but not sure if it can source them.
Basically I'm looking to retrieve data from a piece of hardware that is SNMP enabled (an SNMP agent) over Ethernet/IP using the PLC.
Any ideas?
Thank you
Any ideas?
Thank you
In the S7 world, I've used a published SNMP library to change which wireless access point an AGV was looking for as it moved around. No reason I can think of shouldn't be possible in AB land.
The question is if there is an existing library, or if you have to build it from scratch with open socket messaging.
Any ideas?
Thank you
Since Prosoft will sell you a dedicated card to do SNMP protocol, and to do the polling of the various 'layers' .. I'd guess that it's not easy to do.
A quick search of Knowlegdebase gave me tech notes on what the default Rockwell passwords are, how to change them, which products support SNMP. No info on how to source SNMP messages.
It may be possible ... I have not been successful in searching Knowledgebase in the past .. I may be using bad search terms
SNMP - Not so Simple?...
mugged99 said:
...I'm trying to figure out if it's possible for an EN2T card along with an L7x processor be used to send SNMP protocol messages?
First...
493224 - SNMP commands from a ControlLogix PAC
Access Level: TechConnect
So that's a Roger...and that information also now pertains to many more products besides the older 1756-EWEB...
470690 - Open Sockets Support in ControlLogix and CompactLogix
...and some reference material and examples...
48879 - Summary of Logix Open Sockets Information
Regards,
George
First...
Regards,
George
Thanks Geospark. You are obviously much better at this searching thing than I am.
I am always amazed at what information I am not able to locate in Knowledgebase!
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
130
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
131
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
