RS LOgix 5000 S88 /Phase Manager
cjd1965
Apr 2007
UK
1,659
Hi I have a project where I need to use RSLogix 5000
I have only used Siemens and Mitsibushi for the last 5 yrs and don't have RS Logix
My supplier has quoted me for the mini version but I then found out I need to follow S88 principles so my supplier has quoted me for the phase manager add on
Before I buy any software do I need anything else? The last phase manager code I looked at used SFC code within the running/stopping etc phases for example.
My suppliers software specialist has no experience with phase manager
To summarise
Is the mini package with phase manager option all I need to write S88 compliant code ?
http://www.theautomationblog.com/which-rslogix-5000-package-is-right-for-you/
This link might be a little outdated?
I can't speak to S88 or phase manager. You already mentioned the ladder issue, (mini alone is limited to ladder.) Just want to make sure you know mini alone, (I know nothing of phase manager) is limited to programming CompactLogix. I bought the mini in October and received disks with installs for StudioLogix ver. 21 and RsLogix from ver. 20 down to 13. Love it and the learning
Regards
Hi thanks for the reply, I was aware of the compactlogix limitation.
The high cost of RSLogix 5000 pro for a one off project is a stumbling block lol. In the uk they saw 5000 and put a pound sign against it.
I just want to buy what is needed for the job to be done well
Cheers
You can program anything to fit the S88 principle and you can do it all in ladder if you want to. It may make it easier if you are familiar and comfortable with SFC to have that option but it's not necessary.
The version of Logix depend on the PLC. I think mini can program the compactlogix and not the contrologix line but you need to check.
Also, you can add the SFC option later by buying the language pack as an add-on.
Hi Harryting
To confirm I can use phase manager and use ladder for the code for each phase within...
So ladder for starting code/stopping code etc
My sales rep is useless
Cheers
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
441
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
71
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
153
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
187
