lbric
Hello,
Not an expert at all in comms need some help trying to figure something out. I have a plc and hmi that i am trying to establish rs485 communication betwen the two. my plc is knockoff mitsubishi fx3 that has rs485 a/b terminals. my hmi is a weintek with a db9 port and i am using ezbuilder pro software to program it. the hmi software plc driver is setup for a mitsubishi fx3 rs485 4w which is what it recommends for this brand/model.
the hmi manual shows me that pins 1/2 are rx+/- and pins 3/4 are tx/-
i have connected the rx/tx + to the b(-) terminal on my plc and the rx/tx + to the a(+).
when i power up the plc i can see the value i have stored in my test register for a split second then i get an error message "device no response". I can reboot the hmi and again see my value on startup but then the error message appears.
not sure if i am missing doing something wrong in the wire connections or if its a plc issue. i have read about 120 ohm resistors being used to cancel reflections??? but not sure what that means. i tried placing a resistor across my a/b terminals but it did not produce any positive results. i am trying to achieve back and forth comms.
any help would be greatly appreciated.
thanks
Ricardo
thanks
Ricardo
