RS5000(v17) Pid control of a cooler
lottis11
Nov 2015
adelaide
Hi Guys
I have a cooler using evaps to set up PID to control the humidity. I put ugly step logic in it but although it works (+/- 4% humidity target 65%) i think i can get it a lot better.
I have only four binary points of control, 3 evaporative cooler pumps and an extraction fan. The evap fans have to stay on as the produce the recirc for the cooler. The extraction fan draws dry air from inside, not very effective vs the 3 evaps.
The humidity swings greater here in Adelaide, between 11% and 87% last month
My question is when i change to PID (which i have only set up on analogs) should i run the pumps at say
pump 1 = 100% PID output
pump 2 = >66%
pump 3 = >33%
extraction = 0%
Or is there a better way of setting them up?
Thanks Lottis
I need help in creating Arrays in RS5000 v17 using udts. I am very new to RS5000 and do not have the savy to pull this off by myself. I need to...
3,840
Laptop died today. Picked up a new one. Went to download RS5000 V17 from the Rockwell website. Get a page that it's on quality hold, & a phone...
2,095
I have recently made a career change after 25 years of being an electrician. I am officially a junior automation controls programmer. I recently...
368
Hi Guys, Hoping that someone could please confirm if the 1756-IF16/B is/isn't compatible with the 1756-L1 5550 processor(13.24). I'm sure I...
105
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,209
