RSLinx upgrade EDS files
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
I am running version 2.57, and just downloaded 2.59.
When I upgrade, I normally get to the part where we update EDS files, then I go in and add a bunch of devices to the choices and it takes quite a long time to complete.
What would happen if I unchecked a bunch of the old stuff I already have installed? Will the EDS files already registered still be there?
I suspect the answer is yes, but I am not sure, so a confirmation would be nice.
Thanks,
Paul
You are correct; the previously-registered EDS files will remain registered.
I generally just omit the AC Drives and the ControlNet section and install the rest of the general hardware for DeviceNet and EtherNet/IP, to make the installation go faster.
When I work on a drive, I create or download an EDS on the spot. When I work on ControlNet it's usually a small number of devices for a Redundancy system, so I can get the EDS files off the server for those.
I have just downloaded and installed CCW software which upgraded my RSLinx to version 4.11. This has caused me a problem and I was wondering if...
2,567
Hey all, I am attempting to upgrade a RSLinx install and right at the beginning it comes up with a "INTERAL ERROR 2711.WFCU" message comes up and...
4,228
I want to perform a web update of my RSLinx software (I currently have RSLinx Classic Gateway version 2.50). On the Rockwell support site I have...
5,385
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
