RSLogix 500 and "default project"
rguimond
Jul 2009
Escuminac
666
I've searched for "default project" and end up with hundreds of hits!
What I'm wondering is... Can you set up a .rss file to always didplay as a "default project" instead of having to "window" "arrange" "OK"? Some files open up properly, but I have others that open up with two or three open data tables, half of the screen blank, etc.
I know, it's not a lot of steps to make the project display like expected, it's just strange that it would suddenly open a certain way.
I bet someone has a trick that'll make any project open up as "default project" every time.
I never knew about this feature. Mine always opened in "project default". No matter what file I open out of the 100 or so I have, it always opens with the project tree window on the left and the ladder window on the right, maximized to the current window size.
Edit:
Playing around a bit, I think I found your problem.
Under the File menu is the "Load/Save Workspace".
If you want everything to open as Default Project, just delete your saved Workspaces, or save the "Default Project" as your Workspace.
A feature I never knew about.
Edit Again:
Under Tools -> Options...
System Preferences.
Checking the "output window arrangement" will save things like opened data files in your Workspace. Without it checked, only the open Ladder and Project tree window size/location seems to be saved.
Another feature I never knew about.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
176
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
85
Will someone please convert this logic to pdf?
127
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
162
