RSLogix 500 crashing
geoplc
Oct 2006
PAinesville OH
123
I have a Dell laptop running Windows 7 with the following installed:
RSLinx Classic 3.60.00
RSLogix 500 9.00
RSLogix 5000 V20.03.00 (CPR 9 SR 5)
FactoryTalk ViewStudio 7.00.00
Problem is as follows. Evertytime I attempt to go online with a processor SLC5/05 using ethernet RSLogix 500 crashes. Can go online with DH+/DH485 devices. Able to connect with RS5000/FactoryTalk with a control logix processor and hmi. This is all the info I have for now, have a major breakdown, will try and update as much as I can. Any help appreciated.
Try the usual deletion of the RSCommon\Harmony.HRC and Harmony.RSH files, and try using the ordinary Ethernet Devices driver instead of the EtherNet/IP driver in RSLinx Classic.
You can also reset RSLogix 500's startup options by holding down the shift key when you start it.
That's all I can think of right off the bat.
Ok back, Ken you were correct. Someone left the Ethernet/IP driver running, I never use it but never experienced any issues on our old XP laptops, Im a Windows 7/8 newbie, hate it. After deleting the driver I was able to go online no issues. Thanks to both of you for your quick response.
I have never seen any problems having both the Ethernet Devices and Ethernet/IP driver running simultaneously (even multiple instances of each).... But having said that, I rarely use the "Devices" driver for SLC 5/05's, as the /IP driver picks them up. It may be that your 5/05's are "old", and specifically need the devices driver.
A common problem with ethernet comms to SLC's is getting booted offline when online editing, and this is cured by changing a setting in RSLinx, which I will try to find for you....
Daba, the settings can be found in the link I posted above...
I just figured out a problem with RSLogix 500 V9.0 I went online with a SLC5/04 and had the project on a flash drive, so I browsed to the file on...
1,647
Hi, I've often come here for tips on solving many, many PLC related issues! I'm really grateful. I'm currently trying to use RSLogix Emulate 500...
4,596
More & more frequently I am finding I have to stop the Harmony service. Then delete the Harmony file. ( For some reason only 1 file, not 2. Now...
5,050
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
130
