Rslogix 5000 slow to load
Aug 2017
guelph
Hi All, I'm new to this site and it's my first ever post. Hope to get some answers to a very simple problem. I'm running Rslogix 5000 Ver. 19 on windows 7 laptop, Core i5. To my understanding it's a decent speed laptop. But for some reason, it takes lot of time while loading Rslogix 5000. Does anyone know why it's like that and have any suggestions on how to reduce this time.
RS Knowledgebase 114274 alludes to the problem.
Unplug all ethernet connections and try again...if it is faster then do the following:
Control Panel - Internet Options - advanced
Uncheck:
- check for publishers certificate revocation
- check for server certificate revocation
- check for signatures on downloaded programs
We tried this on different machines and it does work....
Hello!
On Windows 7 it is also a good idea (some may debate but experience has shown) to go to your System settings, set your paging file much larger than the minimum I usually set it to 10 gigabytes. While you are there change the way Windows prioritizes from Programs to Services (background services) this will drastically improve the snappiness to load RSlogix 500 and 5000. Lets all be honest Windows is horribly inefficient with resources. Trust me if Logix5000 was supported on Ubuntu Server 19 I never use Windows again.
Wait until your IT makes you go to Windows 10 and run Windows 7 in a VM, might as well make them spend another $1000 up front and get you a laptop with 20 gigs of ram and the fastest processor they can buy at the time, because it is an absolute nightmare.
What would be causing Rslogix 5000 Versions 19.01 20.01 21.03 and 24.01 to load very slow when im not at work? I have been through the tech...
4,404
This is not my day. My 4-5 yo laptop is barely hanging on and Rockwell site wont' even allow me to log in today, yup, it maybe my computer...
13,073
My RsLogix 5000 is slower than death to launch and open a file. I don't know for sure but I think this started when I updated to ver 19...
4,582
Last week we replaced two computers running XP Pro and RSView 32 with two new computers also XP Pro but upgraded to FactoryTalk SE.(15 displays)...
16,401
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
86
