RSLogix PIDE split range
Zaheer
Apr 2010
Germany
Hi there,
I have to control a temperature (at the outlet of a two stage heat exchanger) with two different heating water lines; 65°C and 95°C. Both have control valves installed.
I want to use the 95°C water only if the set point is greater than 65°C.
Any thoughts how can I imlement this? I am using RSLogix 5000. By the way I am not sure if split range is true term for this.
Thanks in advance for any help.
Thanks widelto.
But I think I did not explained my problem very well.
In any case I want to use the maximum energy from 65°C water.
So if the set point is 80°C, the control valve for 65°C should be 100% open, and the rest of the energy should be taken from 95°C water.
So I will use the 65°C PIDE always with SP range 0-65°C.
and 95°C PIDE only if SP is greater than 65.
What should be the SP range for 95°C PIDE, 65 to 95?
With the same SP for both PIDEs?
Zaheer, when your SP is greater that 65, then PIDE1 is off and valve1 is 100% manually, use move instruction to open your valve.
At this time PIDE2 is working and controlling temp thru valve2.
When SP is less than 65 PIDE2 is off, valve 2 is off you can close it manually if you want it, use a move instruction and temp is controlled thru valve1.
I see no problem.
Greetings ... someone sent me a request for some student handsouts that I developed ... turns out that I had this hosted on my business website...
151
Hello im using PIDE in rslogix 5000 - mode is DEPENDENT. im using it to control the temperature, via burners. im having some problems with...
5,137
While troubleshooting control issues due to windup, it would be helpful to be able to view the error term due specifically to the error term in...
1,901
Hi all, Having some issues setting up a PIDE Cascade control loop. Have been trying to go through the Wp008 doc but there's probably something...
5,713
I have an application that I was wondering if these function blocks could help me out. I work at a hydro-dam (less than 4 MWatts), and we control...
2,616
