I have 2 PID loops controlling a valve, the primary one is controlled from flow, and the secondary one is controlled off pressure if the pressure rises above a setpoint.
I have them setup so that the one in control is in Operator Auto and the one not in control is in Program Manual and the active PID's CV is followed. However when I switch from Operator Auto to Program Manual, the PIDE SPOper Value is cleared to zero.
In Program Manual I also cannot adjust SPOper either in the logic or at the HMI. Ideally I want to set SPOper so that whenever the PID enters Program Auto, SPOper is persistent and will be the setpoint used.
I also want to be able to set SPOper when the PID is in Program Manual, as this affects the switchover point. Am I missing something? Thanks
