RSLogix trends alternative
Bolatov
Jun 2010
Mty
87
Hello guys
Im troubleshooting some equipments but im using some trends to get the problem signal.
The rslogix 5000 only let me display signals per window so im using 4 trends, is there any alternative to display more signals?
what do you guys recommend?
There is a neat trick you can do using AdvancedHMI to give you high speed trend charts for troubleshooting. Start by adding a EthernetIPforCLXCom driver from the Toolbox to the form, set the IPAddress property to that of your PLC, then set PollRateOverride to 0. This will tell the driver to read data as fast as possible. Depending on your hardware, this will typically be in the range of 2-10ms sample rate.
Next from the Toolbox, add a ChartBySampling. Go to the PLCAddressItems property and add the tag names you want to chart. When you run the application, you will see the chart begin plotting points very fast. This can be useful in finding "blips"
You may have to increase MaximumActivePoints because the chart does not retain data after the points go off the chart.
Hello I put my computer to log all day some equipments, and I want to review certain times, but when I open the log file I cant go to the desired...
2,207
Hi, I am trying to gain some data by utilising the trend feature in RSLOGIX 5. I have a trend set up and I walk away. Its logging the data but...
4,970
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
92
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
164
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
181
