S5 R64 PID Loop conversion to S7
Control_Aus
Jul 2009
Aus
I am in the process of upgrading an S5 system to S7 which has a number PID loops configured using the old S5 R64 software. I am hoping to use the parameters from these old blocks as a starting point for tuning the new S7 system (which shall be using the standard Cont_C block). Has anyone had any experience with this process? Would you try to transfer parameters or would you retune the system? If possible I would like to transfer parameters as there are only very short commissioning windows available.
hi I need programme COMREG to configuration R64 . Where from can I take ? It thanks by means and answer ps. it in Siemens it was one should was pay
1,717
I am working on a large migration of the standard PID instruction to the PlantPAx P_PIDE. Has anyone done a migration like this before and have a...
53
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
141
105
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
107
