S7-300 Modules - Profinet
mad4x4
Mar 2009
ST CYrus
363
Can these modules :
Code:
S7-300 SM321 16DI 120/230VAC	        Siemens	6ES7321-1FH00-0AA0
S7-300 SM331 8AI 16Bit	                Siemens	6ES7331-7NF10-0AB0
S7-300 SM332 8AO 12Bit	                Siemens	6ES7332-5HF00-0AB1
S7-300 SM322 16DO Relay	                Siemens	6ES7322-1HH01-0AA0
Be used with a ProfiNet Interface Card, If so which one?
These are all ET200M i/o
Looks to all work with this one
6ES7 153-4AA01-0XB0
Put this in your hardware config with Step7
The AO is a AB0 though
The part numbers ( 6ES7321-1FH00-0AA0) & ( 6ES7322-1HH01-0AA0) are actually correct as these are older revision cards that we have ( legacy stock) from a project that was new but mothballed before it was built. (Also have a load of spares).
Will the 0AA0 card work, even though they are the older revision?
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,208
Hello my fellow plc masters. I have come to ask you again :D Lets start the story. A few days ago i've made a post here about a s7-300 plc and...
19
4,587
Hello, We have a system integrator at a site that is reporting that the IO modules in a S7 expansion rack (using IM360/360 modules) are crossed...
2,727
Hi all, When configuring S7300 analog module with 4-20 mA range, there is an option called Measuring Type, and I should choose 2DMU or 4DMU. I...
4,347
Hello all, I am replacing some old Siemens S5 modules (6ES5 646-8MA21) with S7-300 that measure thermocouples. I have been looking at modules...
1,330
