Safety system and muting
rQx
Oct 2010
Trelleborg
1,051
We are developing a safety system containing a emergency stop and some limit switches on some lids. We want a switch to be able to mute the lid because it need to be operated for service with the lid open. I'm not that familiar with this and thinking over what switch I should use for this.
In the past I have used a switch and key from rockwell 440T series, however this is pretty expensive but it does have a B10d value.
I would like to use a regular keyswitch from the rockwell 800F series, but I can't find it to have a B10d value. How would I go about to verify if I can use a switch like this for my purpose? Ideally I would use a NO block on the key switch so it would bypass the lids when turned. I have also thought of using the self monitoring NC block for emergency stop buttons, having it always turned for operation and released to bypass the lids. But, I can't find a B10d value for the block, only combined with an emergency stop button.
/Tim
I would ask locally for a safety person who can guide you in the safety process, i see your from sweden. This safety person is usually associated with AB, pepper_fuch, or some distributor who would give you some expertise in what you would need for this application. I remember this person in my area had some credentials in safety and TUV rating and other ratings that gave me the correct safety solution.
Yes that is one of the ways I'm also going to for. I usually want to get more knowledge about the subject first, and also we have an consultant for the risk assessment part that will evaluate the solution also that we come up with. I have been tasked to assemble the solution components and I'm basicly there having the project in SISTEMA and all is evaluated for PLr and PL.
But for this "muting" I would like to know if another solution can be applicable. If I can't find out I will ofcourse go about and confirm it with someone else. But this forum has great experience so it may be that someone has done or have the knowledge.
I am working on a program that was developed in 2015 for an S7-300 safety PLC. The new copy of this machine uses an S7-1500 safety plc. We were...
1,911
Safety for a motion system that is like 30ft+ in the air and not normally accessible? We are looking at designing a sprayer that moves back and...
2,071
We have a legacy winch system that was built back in 1975, we are looking to replace all the controls (electrical) on this and bring it up to...
1,918
I am working on a very large machine at the present time. This machine has several safety zones and up to 8 light curtain guarded areas. It is...
31
9,730
I've heard mixed opinions on this matter but if a machine is to go through a control system upgrade to what extent are you liable for reviewing...
3,278
