SCADA acronym right or wrong?
Outrage
Jul 2006
Nottinghamshire
173
Hi all,
I've always been under the impression that the acronym SCADA stood for "Supervisory Control and Data Aquisition" At the moment i'm dealing with a large systems integrator that keeps insisting the abreviation is "Sequential Control and Data Aquisitian" Since i'm being regarded as a complete imbasile (probably down to the fact that I wear overalls not a shirt and tie - despite 10 years previous programming SCADA and PLC) i'd like to get one up - BUT I thought i'd run this by the masses in case this changes from country to country.
Just to clarify, the SCADA is RSView interfaced to several SLC500 PLC's over ethernet.
I have never even heard of any other variations, this doesn't mean it doesn't exist. Really, "Sequential Control" doesn't even make sense in this context. Well, if you want to "get along" I would just ignore the dude.. or you can print out the Wikipedia article and post it in the lunch room :)
I know the term HMI and SCADA is used interchangablly at time, however; to me, SCADA always covers more than one machine/process and usually over a larger geographic area (such as an entire city).
Posting it in the lunchroom sounds like a class idea! (y)
Cheers,
Lee
I believe that acronyms like "SCADA", "SPOOL", "BASIC" etc. are reverse made i.e. they first find a suitable word like BASIC and then construct a acronym of it...
I'd even go so far as to say "sequential" is dead wrong and they are the idiots. SCADA systems are usually anything BUT sequential! They are not necessarilly even the local control, but rather the overall system, hence the "supervisory" aspect. Within a SCADA system you may have some local sequential controllers, some analog controllers, some PLCs with both, some relay panels, a DCS system, simple monitoring systems, etc.; an entire mix of local systems and technologies all being monitored and controlled at a "big picture" level.
In the words of Bugs Bunny... "What a maroon!"
Print out the Wiki article and all of these to over-state your point. Then print out this forum page so he can see that we think he's a maroon!
http://www.tech-faq.com/scada.shtml
http://www.webopedia.com/TERM/S/SCADA.html
http://www.securityfocus.com/news/11351/
http://ref.web.cern.ch/ref/CERN/CNL/2000/003/scada/
http://www.sss-mag.com/scada.html
Love that one Pierre!!!
The definition for SCADA from Wikipedia is correct.
Perhaps you should direct the idiot to Pierre's referred page. Sounds like he is a used car salesman.
I think the dude came from the automotive industry.
Fancy cars used to have sequential turn signal.
The acquisition part is how long it takes for the guy behind you to react.
Hence...Sequential Control + Data Acquisition.
Glad To Be Of Help!
At one point a couple years ago, we set up an Entertron "Smart PAK" PLC for Sequential turn signals for my son's 71 Mustang.
Everyone should have one. (A 71 Mustand, and a "Smart PAK")
Being ignorant, or even wrong, is acceptable and forgivable. I could forgive that guy for not really knowing what the acronym stands for, it's not really common knowledge. What frosts me about this situation is the guy's insistence that he is right, and the YOU were wrong, and he is a supposed "professional"!
By the way, totally forgivable, but it's spelled "imbecile", and no you are not one. I just thought I'd offer that because of the irony of spelling it wrong when trying to defend yourself from being treated like one.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
50
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
68
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
70
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
285
