Schneider Zelio relay logic
I got struck in the middle of writing a logic for automatic change over switch.
my task is to change the control from mains supply to generator supply when there is a power failure. I have written the logic and its working fine.
I need a 20sec delay when the change over happens. Could anyone help me in writing a timer function for this changeover.
Till now, i have written logic which i am sending to you as an attachment.
switch I1(Row1, Column2)-------is connected to phase failure relay.
when I2(r1c1) is closed, i.e, In auto mode.
when I1(r1c2) is closed it should delay for 20sec before it activates q1. but it isn't.
but when I1(r1c2) is open it is taking a delay of 20ms and activating q2. its working fine.
pls help.
Here is a little something I was trying before you posted the screenshot. Attached is my example, maybe you can use it for ideas. I was using the ZelioSoft-Com software for my example. I have since downloaded the ZelioSoft 2 to open your attached file.
Thanks mate, that really worked. Now i can switch is either way.
I am a graduate engineer and this is a totally new feild to explore.
where abouts in US are u placed mate? Hope u have a good knowledge of PLC's. What ur are working as?
I really appreciate for ur help mate.
Keep in touch theres more to come.
Sorry, I deleted the post to re name the attachment. The file is the same. Here is the attachment again.
PS. I am retired, located on the East Coast in North Carolina.
zelio
hi mate,
i am working on this automatic transfer switch logic.
the program works fine in the software when i simulate it.
but, when it is connected to actual hardware and bench testing apparatus to simulate and verify correct logic operation ....it fails.
how different is it that it works in the simulator in the software and fails when connected to actual hardware.
any ideas,
cheers,
sandeep.
As best you can, please describe in detail step by step as to what is and is not happening when it fails during bench testing.
It would help to have a physical wiring diagram of the transfer switch as well as make and model. A pdf manual would be nice as well as a web-link to the transfer switch manufacturer. There could be any number of things keeping it from working. What first comes to mind is interlocking contacts as well as mechanical interlocks to prevent both contactors energizing at the same time.
PS.
Tharon types faster than I do :)
Hello everyone, I currently trying to get a Schneider Zelio SR2 B121BD programmable relay to communicate with ZelioSoft 2 v5.2.0.0. The PLR...
1,594
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,552
Hi, Just unboxed our Schneider Zelio SR2 A101FU , loaded zeliosoft 2 v4.5 and I cant for the life of me talk to the PLC, I get error DC46_10 ive...
4,358
I'm not familiar with this software at all. I have most of the ladder logic working except for the fact that I need two pumps to alternate, or...
4,400
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
61
