Self monitoring Emergency stop drawing
JeffKiper
Jun 2006
Indiana
2,460
I can't figure out a way to show these self monitoring Emergency stop contact blocks on a drawing that looks good and makes it easy to under stand.
I am using 2 contact blocks on each Emergency stop push button. I am sure there is a nice clean way to make these things look correct but, I am just missing it. Do you guys have any ideas?
Here's a screenshot of my pretty-much-standard E-stop button symbol. My E-stop circuits are almost always single circuit, with a self-monitoring contact. If I need to, I also added a separate N.C. contact block to the schematic in this picture; I use it for reporting individual button status back to the PLC if the machine has multiple E-stop buttons.
-rpoet
Jeff,
Am I correct in reading your drawing that the same signal is going through the 2 contacts?
whilst it will work fine, it does not follow the pattern of dual channel.
Osmanjdt example is correct implementation of dual contact/channel .
I was just showing an example of 2 contacts in a series. You are correct it is NOT a dual channel system. If I series multiple Emergency stops on a single channel it would effectively look the same without the dotted line going from the fist block to the second.
Hey guys. Got a strange one. Was sent to a site where the VNC access is very poor. The IT has assisted and a Wireshark report shows data...
325
Hello friends I think this is the second post about this all over the internet, first one was in 2013 by some guy from Canada who experienced the...
26
6,472
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,430
Hello Friends, I'm starting a new job soon, towards the end of September, that will be using all Beckhoff equipment. I have programming...
1,068
Hi all, Any experience of the above? Happened 3 times now in 1.5 months. Processor is about 10 years old, software major revision is 19...
5,547
