SEW IPOS Drive Assembler Code conversion to PLC Ladder Logic
adnan_hayat88
Apr 2013
Karachi
46
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The existing SEW drive is MOVIDRIVE B; with IPOS program running. I want to replace using the IPOS program with PLC logic routine.
The drives are communicating with Rockwell control system via ethernet communication. I tried extracting compiler code from the drives but unfortunately the drive does not contain compiler data.
Your MOVIDRIVE unit is the MDX61B? You connected to the drive using the MOVITOOLS motion studio software?
Yes, the unit is MDX61 and we connected to the drive using MOVITOOLS motion studio software and extracted assembler code and parameter file via MT Manager. Now we need to convert assembler code to PLC Ladder Logic.
Have you thought of using the bus positioning application in Movitools? Commissioning the vfd using bus positioning allows you to use PLC logic for all drive functions. Using 3PD gives you drive status, actual speed, and actual positioning as inputs to your program, and drive command, speed command, and position commands as outputs from your plc program.
The bus positioning module writes an IPOS program to the drive.
Hi All, I'm in desperate need of help! On a customer site they have two movidrives linked together using an application module called...
2,120
Hello I need to control a Sew Eurodrive MDX61b position (HI and LO) from a PLC S7-314-2DP with Ipos and I don't understand how to use the strong...
1,576
hello. please tell me which h parameter in attached ipos program is related to po1,po2,po3 and pi1,pi2,pi3 beat regards.
2,240
Hi All, I'm just writing an application with IPOS, which is similar to the built in positioning application from SEW. In addition to the functions...
2,923
Hi. Working somebody with IPOS movidrive? I have problem with it. When I set IPOS, sometimes it set 6 word for komucation on profibus, sometimes...
2,147
