Hello,
We have a slight problem using the new SIDirect OI Server G-1.1. First of all: we have a Siemens CPU S7-1500 and a project in TIA Portal v13. We want to use Intouch as a visualisation. And apparently you need to use the SIDirect OI Server G-1.1 to do this. We configured everything as was said in the manuals, but we cannot find how we need to configure the access name in Intouch, or at least not a correct way.
For the moment I have set this to:
Node Name: (empty)
Application Name: SIDIR
Topic Name: Symbolic_Normal
However, when we start up the WindowViewer we get the question if we want to start 'SIDIR.exe' (in SMC this is already activated, so this is already weird).
If we say Yes, we get the message:
'Cannot start application SIDIR.exe. Make sure the application name is correct and that the location of the application is included in your path'
Does anyone know what I'm doing wrong and what the application name should be?
Thanks in advance,
Mich
Node Name: (empty)
Thanks in advance,
Mich
