Siemens 505 Illogical ladder
as these internal coils are used more often (copy pasted as I understand), is it maybe possible the software shows a "end of program scan" state instead of an, as expected, "current" (at shown rung) state?
Yes, the way the scan works is the X inputs and Y outputs are read from/written to at the end of the scan. So regardless if the state of your C1821/C1822 after the Y coils were set, they will be ON at the end of the scan. Of course, only if the C1821/1822 coils were set BEFORE this rung.
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,266
We've a 555-1106 with one remote base and three other PB devices. This base has a 505-6870 RBC, and three modules / IO cards. I am trying to add a...
1,582
Good day - I have scoured the forum to no avail. I have a Siemens 555-1106 rack with a remote base on RS485. It does not currently, but will be...
2,166
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,666
Hey all, I have a project in the works to replace an old Siemens 505 rack, unfortunately the rack contains a 386/ATM card and two BASIC modules...
3,036
