Siemens ET200X
SWilczek
May 2008
Detroit, MI
I've got an ET200X w/built-in DI-8. It also has another DI-8 and a DO-4 (142-1BD40-0XB0). I'm only getting 12 V out of the DO-4. I verified that the ET200X has 24 V coming in. I haven't replaced the output module yet. I have two machines with similar configurations and they both have the same 12 V problem.
If anyone has any ideas, please share.
Thanks in advance,
Scott
I have a problem with Siemens CPU 315-2DP with 2 ET200X conected, when I go in stop and next in Run on PLC on ET200 and PLC there is the led Bus...
3,093
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
292
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
159
