Siemens FM458 : learning curve
Plc_User
Dec 2005
Belgium
317
I am new to the Siemens FM458 card, but in future I will have to do changens on a machine with FM458 card.
How many days would it take to become 'experienced' with this card, supposed I have such a card at my disposal for testing.
What do I need for software? What do I need besides S7 400 CPU and FM458 card, to do some usefull tests in the office.
Share your experience about this card :)
First thing, you will need the source code on the machine
Your doing changes on
Have you used cfc in S7? This is the programming concept.
Buy the D7 SYS software. This will be a start
I recommend you sit with a Siemens engineer.
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
62
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
83
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
162
111
330
