Theboss Member T Join Date Jun 2010 Location Durban Posts 159 Mar 9, 2013 #1 Hi Peepz, I would like to configure the drive as to control the speed via var resistor? AND another to run at two fix speeds, adjustable via a toggle switch?
Anirban Hazra Member Join Date Jan 2013 Location Kolkata Posts 192 Mar 9, 2013 #2 It's all given in the manual.If you do not have one then here is a link to it: Micromaster 420 Operating Instructions
Theboss Member OP T Join Date Jun 2010 Location Durban Posts 159 Mar 9, 2013 #3 which page as i cant find it
KalleOlsen Member K Join Date Oct 2008 Location Norway (moustache area) Posts 1,782 Mar 9, 2013 #4 Search the pdf for 'command source'. It should reveal what you ask for.
Anirban Hazra Member Join Date Jan 2013 Location Kolkata Posts 192 Mar 9, 2013 #5 For running at 2 fixed speeds read: Chapter 3.8 Fixed Frequencies Page 121 For using Variable resistor to vary speed read about: P1000 Analog Input Last edited: Mar 9, 2013
